WTF Mate?
Posted: Tue Oct 11, 2005 10:44 pm
by LaureltheQueen
No passenger side firewall grommets? Is there a reason for this? My boost gauge is going to be mounted right under my radio, and it's a bit of a pita to run the line from the passenger side to the driver's side, to the middle of the car. Any easier way?
Posted: Wed Oct 12, 2005 12:56 am
by LaureltheQueen
doh. found one, but cannot see where it empties to.
Posted: Wed Oct 12, 2005 2:51 am
Tap your boost gauge into either the BOV's vacuum line or the brake booster's hose.
Posted: Wed Oct 12, 2005 3:05 am
by THAWA
Isn't the check valve in the booster hose? I suppose it doesn't matter if you tap after the valve.
Posted: Wed Oct 12, 2005 3:11 am
Oh yeah, the check valve...
The check valve is like halfway through the hose; you can feel it if you squeeze the hose. You'd want to tap between the manifold and the check valve. It should be easy enough -- get a 3/8"-to-3/8"-to-1/8" vacuum tee. I've seen a few Legacies with that done in order to drive an aftermarket cruise control actuator.
Posted: Wed Oct 12, 2005 6:20 am
by LaureltheQueen
I just ran the line under the intake manifold and tapped into the line coming off the manifold on the pass. side
Posted: Wed Oct 12, 2005 8:03 am
by dzx
Cant you use the grommet on the driver's side? Or is there not one on the wagons?
Posted: Wed Oct 12, 2005 3:37 pm
by LaureltheQueen
dzx wrote:Cant you use the grommet on the driver's side? Or is there not one on the wagons?
LaureltheQueen wrote:it's a bit of a pita to run the line from the passenger side to the driver's side, to the middle of the car. Any easier way?
Posted: Wed Oct 12, 2005 4:08 pm
by azn2nr
its a pita if your using that hard line stuff. not a pita if your using a vac line and deff not a pita if your tapping the bpv line.
Posted: Wed Oct 12, 2005 6:13 pm
by LaureltheQueen
I used the hard line stuff wrapped in a vacuum line all through the engine bay, and had no huge problems with routing it. I'll likely continue to use it until I encounter a problem. The nice part is, It's skinny running through everything, and I'm not worried about it getting kinked as I would be with squishy vacuum line. And yes, I know if it gets kinked, it's more permanent than a kink with a soft vacuum line.
