Turbo Exhaust Stud Replacement info
For those that need to replace the studs on the turbo, you can pickup some HELP! ones with the following part # 03400.
They're meant for Toyota, but work. The only difference I could see is that the spacer where no threads are is slightly longer. There "should" be enough thickness on the down pipe plate to not have it be a problem. You could always use a washer too.
Yeah, those should work fine.
They can also be used as uppipe studs.
