cel after rain/snow HELP! asap!
92whitelegacy
Post by 92whitelegacy »
anytime it rains hard, or snows my CEL goes on and stays on for as long as it takes to dry the engine while driving. Any ideas on why this might be happening? im stumped
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
Manarius
Post by Manarius »
One of the knock sensors is getting wet. I wouldn't worry about it unless your car starts acting weird.
legacy92ej22t
Post by legacy92ej22t »
The one knock sensor is probably getting wet. ;)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
92whitelegacy
the car does start acting weird its drives like it should but when u get on it it only feels like its boosting about 7 psi. When in reallity the boost gauge clearly reads about 15psi so that is what worries me
legacy92ej22t
Well, the ECU will go into a limp mode when it doesn't see the knock sensor signal. So even though you may be running 15 psi the ECu is retarding timing so the car will feel slow.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
All_talk
Post by All_talk »
A wet knock sensor will set the timing to a default retarded position which will cause a big drop in performance. Sounds like your system is functioning correctly.
I'm guessing you have removed the deflector under the scoop... makes it far more likely to get water on the knock sensor. This is a common enough problem, maybe we should look into making a shield of some sort.
Gary
Manarius
Post by Manarius »
legacy92ej22t wrote:The one knock sensor is probably getting wet. ;)
lol. It's a knock censor nonetheless.
92whitelegacy
thanx guys! How should i fix this, this sounds like thats what it is. whats a good solution? I had the shield removed when i put my wrx scoop on
92whitelegacy
where is this knock sensor located? and how should i remedy this annoying problem? its raining now and im PISSED
knock sensor: black round thing with white connector
http://www.main.experiencetherave.com:8 ... P_2481.JPG
92whitelegacy
ok, i THINK i found it. do i have to remove anything to find it? or is it visible when u pop the hood? and how do i stop it from gettin wet when i find it. Sry for so many questions but ima nubstar ;)
All_talk
Post by All_talk »
The knock sensor outputs a very low level signal and typical uses a shielded lead to protect that signal. I suspect the sensor itself is potted or sealed and that the water short may be in the connector or other point in the wiring harness. A good coating of contact grease in the connector may be all that needed, but I haven’t really looked into it. When I get around to installing my TMIC and pulling the deflector I’m sure I’ll have to address it... after all, what’s the point of having a Subaru you cant drive in the snow. :lol:
Just some thoughts
Gary
