edit: the picture is apparently ungodly big so until I resize you'll have to live with a link -
http://www.thawa.net/gallery/albums/Other/IMG_0278.jpg
The rest - http://www.thawa.net/gallery/Other?page=3.
It's single wall construction. The sides and blue end are 2.7 oz/sq.yd silicone coated ripstop and the bottom is 5.4 oz/sq. yd K-coat ripstop. The vesitibule 1.9 oz/sq. yd coated with a sealant and a fire retardant, the door is the same material. All rienforcements are double stitched and the floor/wall seam is triple stitched as is the top, all stiches 10-11 stitch/in. Inside there are are ties for a frost liner as well. Finished weight, minus poles, 3.8 lb., for a one person 4-season, I'm pretty happy. I say one person but I did design in room for when I find a girl that likes this kind of stuff.
I'm still working on finding some alumn. poles that I like (still thinking CF later) and the pictures are a little blurry. I also did my trig wrong and the vestibule is slightly out of size but a quick fix will have it nice and tight. I'll also be adding a little more ventilation to it as the door is the only ventilation now, but there aren't bugs in the winter time... Friday I'm heading out to a favorite spot to see how it does.
So if there are any other winter packers, what do think? Also, what do you sleep in and do you like it?
