wrx intercooler or ver2 jdm sti intercooler
Front, Top, Air, Water.
pw422
Post by pw422 »
Which one is better? wrx intercooler or ver2 jdm sti intercooler. I know the ver 2 sti intercooler is a direct fit , but is it better cooling than the wrx intercooler?
91 rio red ss 5mt
94 legacy wagon gt
95 impreza ej20 swapped
THAWA
Post by THAWA »
What year WRX intercooler? The STi intercoolers up to version 6 I believe are all the same as the wrx intercoolers of the same year. The main difference is the inlet tubing.
scoobiedoo22
Post by scoobiedoo22 »
There are two pdf articles from AutoSpeed that test and compare just about every i/c and awic Subaru ever produced, either here or overseas. It includes has bench flow rates and core sizes. Try doing a search, iirc Josh posted these originally.
1991 Legacy SS 5-Speed
1999 Impreza 2.5RS Coupe
pw422
Post by pw422 »
I am talking about 1993 ver2 sti intercooler and the current wrx intercooler.
hit this link and scroll down
www.angelfire.com/md3/91turbolegacy/newcar.html
91 rio red ss 5mt
94 legacy wagon gt
91White-T
Post by 91White-T »
Thats definitely not a direct fit. The turbo-> ic pipe is for straight outlet turbos. Maybe if you have a 16g/VF18/12 its a direct fit, but not for a VF11.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
azn2nr
Post by azn2nr »
dont forget the coolant tank
-jason
pw422
Post by pw422 »
well I do have a tdo516G and I removed the header coolant tank. maybe what i should have said was the ver 2 is easeir to stall than the current wrx. If they both cools and flows similar, I rather get the current wrx intercooler because there is a bunch out there on ebay and they are rather inexpensive.
91 rio red ss 5mt
94 legacy wagon gt
91White-T
Post by 91White-T »
Ahh, I didnt know that. I would say go with the WRX (newer), the install isn't THAT bad, especially if the coolant tank is out of the way. Here's a tip, get some washers to lift the back of the hood up, your clutch reservoir will make the IC sit up high(at least mine does), but its not a huge deal.
