Yellowed/De-yellowed Headlight pattern
All_talk
Post by All_talk »
Just thought some of you would like to see how badly the yellowing affects the pattern of the lights. These pics are of my ’91 SS lights against the shop door, first with only the drivers side cleared, second with both done (cleared by wet sanding with progressive grits 400 to 1500, then power buffed with polishing compound). One thing the pics don’t really show is how much brighter and whiter the cleared lights are, guess the camera just didn’t catch it.
I know a lot of people complain about the pattern of that early Legacy lights, and I’ll agree they aren’t the best, but with clear lenses they are much better. I do like the way they throw some light out to the shoulders of the road, good to follow the fog line or catch that deer before it jumps outs.
Gary
professor
Post by professor »
For those contemplating doing this, I found the sandpaper to be completely unecessary. I just used a power buffer with medium and then fine compounds and did two sets in about 30 minutes. One of the sets was the worst yellowing I've ever seen, and it came off completely with just the buffer
lftlanelegacy
Post by lftlanelegacy »
i thought the yellow build up was on the inside of the lens? i hope im wrong.
also what if i dont have access to a buffer? anything will help
oh and just pm me plz with any reply.
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
get a buffing wheel at the local hardware store. It attaches to your drill
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
It's generally on the outside. It seems that the damage comes from sunlight rather than the bulbs' light.
Post by 555BCTurbo »
I used fine steel wool and then rubbed it with Blue Magic Chrome Polish...did a fantasgreat job!!
The lights really aren't all that bad you know...:-/
subawhatsubawho
Post by subawhatsubawho »
I just did the set on my Altima. I used 800 W/D followed by 2000 W/D and then hit it with some clearcoat paint. Looks like new.
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
LaureltheQueen
Spelling Nazi
Spelling Nazi
Nice writeup Laurel!!
Is that your previous Legacy, or one that you stole, or borrowed rather, for the demonstration?
555BCTurbo wrote:I used fine steel wool and then rubbed it with Blue Magic Chrome Polish...did a fantasgreat job!!
Yes they are, once you see how GOOD lights look. It is truly night and day difference between the crap that was on the car and the ECE lights.
Nick has a post-facelift, Josh... his headlights are indeed pretty good -- they're an approximation of your ECE lights.
gotcha....thought he was referring to the 90-91's.
LaureltheQueen
Spelling Nazi
Spelling Nazi
555BCTurbo wrote:Nice writeup Laurel!!
That was my 91, the original partwagon. Note the remnants of electrical tape displayed on the headlights. Those are what was left of the car's ricer "costume"
Manarius
Post by Manarius »
I personally think the sanding with the #0000 steel wool works very, very well. You just gotta scrub hella hard in a wet sand.
tris91ricer
Title Whore
Post by tris91ricer »
I can attest to the steel wool method Jason is describing.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
Those of you that have done the steel wool or other polishing compounds......did you clear coat the lenses?
In either case, has the yellow returned at all?
Manarius
Post by Manarius »
Legacy777 wrote:Those of you that have done the steel wool or other polishing compounds......did you clear coat the lenses?
No. And....No.
subawhatsubawho
I found that using the wet/dry method is just as effective as the steel wool route and really doesn't require any more effort. I have tried several different methods and have found that W/D 800 then 2000 followed up by clearcoat yeilded the best results in the shortest amount of time.
Whats scary is when you apply the clearcoat and it is hazy as hell and you think you F'ed something up big time but when you come back to it in a few hours it is dry and the lights look like new.
I've become so good at it that I can do them while still on the vehicle and I have been getting requests from friends and family to do theirs as well.
For a temp fix you can rub a good degreaser such as purple stuff or greased lightning on to the lens, let it sit for 5 minutes then wipe off yellow with a rag untill you can no longer get it off, Then rinse well. Try no to get concentrated degreaser on your paint.
