Power window problem
My power windows suddenly stopped working, nothing really led on to it, they worked one day, didn't work the next. None of the windows work. Checked fuses, also went and took out the front seat and checked the fuse under the carpet under the front seat and its fine. Have no clue what to check now...
'93 Subaru Legacy Turbo Sedan, 5mt
All of them on each door? Or just the controls on the driver's side door? Maybe one of the connectors got loose...
open up the inside of the doors and see if you can test the leads to the switches with a multimeter to see if there is an electrical flow both before and after the switches.
185,000 miles
185,000 miles
