Do Pedal Sets from WRX fit
dwreck30
Post by dwreck30 »
Not sure if this is where I should post this but oh well. My question is does the whole pedal set from the wrx fit into my legacy? My clutch pedal is sqeaking and sticking right where it disengages and is getting kind of annoying. Pedals are out of an'04-'05 if that matters. Thanks
- Derek
'06 STi
It should. However swapping pedals sucks!! I'd try and find the problem with your current pedals.
dwreck30
Post by dwreck30 »
Well, in case anyone cares they do fit, but not perfectly. Old pedals were harder to get out than the WRX ones going in. The bolts holding the clutch and brake boosters lined up perfect, but the the other three did not match perfect. I was olny able to get one bolt in for now. Overall, I like them as the pedals do not take as far to disengage the clutch, and the brakes are right at the top of the pedal stroke.
- Derek
'06 STi
georryan
Post by georryan »
How's the stickiness problem? Is that solved now?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
dwreck30
Post by dwreck30 »
Well I thought it was, but now I'm having them same problem just not as bad. Is there anything else that would make it stick now that I know its not the pedals?
- Derek
'06 STi
What exactly do you mean by sticking? Is the pedal just not coming all the way back up on its own? Because that could easily be air in the system. It's hard to get all the air out of the clutch hydraulics.
Or it could be a failing slave cylinder; have you looked closely at the slave cylinder to make sure it's not weeping brake fluid?
dwreck30
Post by dwreck30 »
Yeah, It does'nt always come up on its own. I have not checked any of that before. I'm pretty sure there aren't any leaks though. I can live with it for now.
- Derek
'06 STi
Hmm... Well you might want to save up for a replacement clutch slave cylinder. If you have to, you can probably get away with using one from a WRX -- I have been for a long time.
