High-Flow cat?
93Leg5spdTurbo
High-Flow cat?
Post by 93Leg5spdTurbo »
I'm finally upgrading my cat. Can anyone recommend a good hi flow?
Post by BAC5.2 »
Any, most cat's are the same.
wiscon_mark
Post by wiscon_mark »
Stromung makes a good bolt up highflow cat :-)
Although the fitament might be a little different on turbos...it'd probably just be best to get a universal high flow (like magnaflow) for pretty cheap and have an exhaust shop mandrel bend up some pipes for you.
185,000 miles
DLC
Post by DLC »
I'd recommend getting a metallic substrate cat instead of a brick one. It'll be more expensive, but it will also make more power, last longer and be smaller. Random makes the one I put on my 00, and may make a WRX downpipe with cat. The easiest way to tell the difference between the two is the size and shape. Metal cats are very short and rounded, like this Cobb unit:
http://cobbtuning.com/wrx/images/downpipe-med.jpg
Legacy Central
gt2.5turbo
Post by gt2.5turbo »
you dont need a cat...... who wants those?
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
wiscon_mark
its actually better if you do have a cat. People tend to fry o2 sensors and have other problems if they get a track pipe, also emissions would be a problem without a cat.
185,000 miles
Be nice to the environment.......you do like to breath don't you.
93Leg5spdTurbo
Thanks guys :)
legacy92ej22t
Post by legacy92ej22t »
Carsound-Magnaflow.
I run catless 11 months of the year and haven't had any 02 sensor woes.
I did have o2 sensor woes in the past though when I was catted.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Project_Legacy
Post by Project_Legacy »
i have a question on this. im gonna have to do emissions this year, in like about, 8 months, and i was looking towards a hi-flow cat. right now i just have a 3-inch SS bellmouth downpipe. would all i need to pass emissions be the 1 hi-flow cat?
Are you guys able to pass emissions that way? i just dont want to have to retake an emissions test cuz it didnt work... thanks in advance.
00 5MT AWD 2.5 RS - New Project
Project_Legacy
anything at all guys? hi-flow cat guaranteed to pass emissions no matter what right??
legacy92ej22t
wiscon_mark wrote:its actually better if you do have a cat. People tend to fry o2 sensors and have other problems if they get a track pipe, also emissions would be a problem without a cat.
Another point Mark, the O2 snesor is pre-cat on the turbo BC/BF.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Project_Legacy wrote:i have a question on this. im gonna have to do emissions this year, in like about, 8 months, and i was looking towards a hi-flow cat. right now i just have a 3-inch SS bellmouth downpipe. would all i need to pass emissions be the 1 hi-flow cat?
It depends on the area. I don't know what Washingtons emission laws are but here in PA, I pass with just the one mid-pipe high flow cat.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
wiscon_mark
legacy92ej22t wrote:Another point Mark, the O2 snesor is pre-cat on the turbo BC/BF.
uh, I have one as well, but I have 2 o2 sensors, one pre-cat, one post-cat. Is this an OBDII feature only?
185,000 miles
Project_Legacy
thanks for the info. i was askin becuz i know i am running a lil rich even at idle because i am using an all stock ej22t fuel system on my ej20g/ej22t frankenstein motor. im worried about not passing emissions. does anyone here in the washington state area know anything about this???
Post by BAC5.2 »
The second O2 sensor for OBD2 is a tattle-tale sensor. If the wave mirrors the front sensor, it throws a CEL saying the cat is inefficient.
That's its only job. To tell the ECU that you don't have a cat.
wiscon_mark
oh, okay, thought so.
185,000 miles
douglas vincent
Post by douglas vincent »
Having a cat wont garantee that you pass emissions. You engine still has to run clean.
If you are running rich, and fail because you are running rich, I bet you could install a 50k poteniometer into the MAF signal line and pull fuel just for the test. ie, you trim the MAF signal about 10%, which trims fuel.
Project_Legacy
uhh. does that work like an AFC? sounds similar. how would i be able to figure out how much fuel i would need to trim? does anyone have injector numbers for the ej20g? i heard of 2 of em. 440cc and some other number. the ej22t has 370cc injectors right? is it safe to say that the ej20g's with the vf8/vf12's had the 440cc's and the ej20g's with the vf10 had the lower numbered ones? i always wondered about that. can anyone confirm this??
Kelly
Post by Kelly »
I passed Oregon DEQ last year. No cat, 234,xxx miles.
Splinter
Post by Splinter »
Anyone know anything about cats that are designed to withstand anti-lag?
Ive seen a few on the net but I dunno if they're actually any better
Project_Legacy
rallitektech wrote:I passed Oregon DEQ last year. No cat, 234,xxx miles.
is that car stock? i know my car is running rich so i doubt i will pass.
anyone have an answer for my injector question??
