Just picked one up for cheap.
The car still has to pass emissions so what kind of exhaust setup do I need.?
How big is the wrx downpipe 2.5 inch does it bolt right up.?
WRX down pipe??
turbonator
Stock WRX downpipe? I don't think it is really an upgrade at all except that you would have a fresher cat.
you should just buy a cheap catless HKS DP or something. You will have to move or extend the O2 sensor.
-max
-max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
true slide
