What's shaking?
dzx
What's shaking?
Post by dzx »
I've noticed lately when i step on the brakes, the steering wheel jerks and starts shaking pretty bad but if i step on the brakes harder, it seems to quiet it down. Do i have a warped rotor or something? My old n/a legacy used to do this too.
///M
'93 Legacy SS - part out
Try rebedding your brakes again.
Imprezive
Post by Imprezive »
what exactly is "rebedding" the brakes?
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
It's different for each brake pad, but typically it involves several consecutive stops (10 or so) from about 60 to 10 mph with medium to firm brake pressure. Then driving for a little while to cool the brakes, then repeat 2-3 more times.
professor
Post by professor »
check the condition of your balljoints and tie rod ends also. if there is play there, the whole hub flops around under braking
rallysam
Post by rallysam »
That sounds like the kind of procedure that wouldn't be appropriate in downtown Baltimore's concrete canyons :-D Maybe if I ran circuits through the industrial area in the middle of the night.
Yeah... I recently did my brakes in here in Cleveland and it was simply impossible to achieve the ideal bed-in. I did my best, though, and have since been going easy on them. Street pads are designed to eventually bed themselves in if you use them gently for a couple hundred miles anyway, so I don't anticipate a problem.
And if you're not using street pads, you ought to have access to a track to bed them in on.
(A funny thing happened as I was doing the bed-in... a dude in an NSX came up behind me and paced me as I went from 70 to 5 and back; then when I was coasting at 5mph for a bit he pulled up beside me and asked what kind of brakes I'd just put in. :))
rallysam
Post by rallysam »
Ha! That's awesome!!!!
legacy92ej22t
Post by legacy92ej22t »
Hehehe, cool. :)
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Tleg93
Post by Tleg93 »
That's cool. It's not every day someone asks about your brakes.
--Scott--
1991 - Rio Red SS
