EJ22T w/25 SOHC heads and turbo.
My question is for anyone who has made this ej22 w/25sohc frankenstien engine. I was wondering if you can use the stock turbo set up, not a custom turbo kit, with these heads? thanks
-max
-max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
No, all the EJ25 heads had the dual port exhaust flanges.
Matt Monson
- quasi-mod-o
Max,
The problem with that is the coolant and the oil for the turbo. I will have to look and see if there are bosses there that can be tapped. I know there are on the DOHC heads...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Matt Monson
- quasi-mod-o
I am building a ej22t/w 2.5dohc heads. Oil and water won't be a problem, i mean only a little moding for oil(there is an pluged oil out near the back of the engine) and the water jackets almost lineup but still should flow good.
Not sure about much else.......
but i have figured that much out.
-Penguin
1978 DL+GL 4WD Wagon (only ever seen 4!!!)
1993 Turbo White Wagon (EJ22t DOHC FMIC, 4.11 5 speed swap with wrx LSD)
1996 Impeza Outback Sport (wifes car)
2002 Suzuki GSXR-1140 Bored and Stroked
(just to much to list... 202mph on radar @ Daytona)
The easiest is probably just the EJ22t w/ wrx heads because they already have the coolant lines. How about setting up a seperate oil system for the turbo? And I am mainly worried about how far the cam sticks the back and would interfere with where the turbo sits in the stock setup.
-max
-max
gt2.5turbo
i think that some of the companies that sell turbo kits for 2.5na motors actually have a different valve cover that has a oil line tapped into it for the turbo. You might try talking to one of them and see if you couldnt just buy the cover from them.....
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
north american subaru cars.
1. 2.0l wrx heads
2. 2.5l wrx heads
3. 2.5l sti heads
4. 2.5l legacyturbo heads
5. 2.5l forster turbo heads
so i have 5 sets of cars that i can bolt on these heads with out totaly customizing everything, now which heads should i get that will make my car faster. i would also need to get the intake manifold also from the car i pick with the heads right ?
1. 2.0l wrx heads
2. 2.5l wrx heads
3. 2.5l sti heads
you can see it here
http://www.main.experiencetherave.com:8 ... P_5952.JPG
The other line runs to the coolant tank
