How to beat a 94 Audi S4?
Calgaryturbo
Post by Calgaryturbo »
My bud just purchased a 1994 S4. It is chipped and he claims it has over 300 hp. He has been talking so much shit lately about how fast this car is so we are going to meet at the track in the spring. I have some money to dump into the tleg now so how do I get enough hp to beat him in the quarter mile and send hime home with his tail between his legs?? I know this thing is fast but also heavy. 300lb
1993 Silver Touring Wagon ,Saab IC, 15 PSI ,MBC, Boost Guage, Ground mod, desnorkified, K&N ,Custom exhaust,
265000KM
legacymax
Post by legacymax »
Frankenstien Engine 22t/25sohc.
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
Calgaryturbo
you mean changing the heads to 2.5?
265000KM
Post by 555BCTurbo »
bigger turbo, more boost, and a perfect power...
Then you should be good to go :-D
Calgaryturbo
whats a perfect power? Engine management?
265000KM
Calgaryturbo
I will do the intercooler this week (saab) , turbo back exhaust, and then a bigger turbo. Any suggestions for the turbo? Do I have chance with these mods ?????? The car is fast now only spooling up to 10 PSI. It hase been maintained very well concidering the milage...
265000KM
legacy92ej22t
Post by legacy92ej22t »
If you want to beat a 300 chp car it's going to require some pretty extensive mods.
Do a bigger i/c then the Saab. The Saab is good for around 250 chp worth of mods max. Even the wrx tmic is probably going to be far too small. I'd go with a nice fmic setup.
For a turbo you'll want to go with a monster 16G, Super 16G or maybe even an 18G.
You'll need a full TBE. Bigger injectors like usdm sti 550cc yellows (at the least) in 92-94 NA rails. Some type of EM (engine management) and probably a built tranny.
Now your car is a lot faster so you'll probably want to upgrade your brakes and suspension so you can control the power, too.
If you're pushing over 300 chp then you'll probably need some head work and should think about a built short block too.
All this won't be cheap. Not cheap at all.
Don't think that you can just throw an exhaust, an i/c and a big turbo on your car and go beat a 300+ chp S4. It won't happen.
Perfect Power is a piggy back engine management system offered by RalliTek.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
dzx
Post by dzx »
legacy92ej22t wrote: Don't think that you can just throw an exhaust, an i/c and a big turbo on your car and go beat a 300+ chp S4. It won't happen.
I knew i was missing something. :razz:
///M
'93 Legacy SS - part out
DLC
Post by DLC »
Your car, stock, is going to be much lighter than his. A stock 94 S4, with the turbo'd I-5, weighs just over 3800lbs. Your TW should be around 3300lbs if it's still running the 4EAT. Both are AWD, but he may have the advantage of a transmission that'll use less of that power, being a 5MT.
BTW, the 94 was 230 @ the crank. If you can get an idea of what his mods are, we might be able to make a better estimate than he has.
Legacy Central
Calgaryturbo
all he has done is the chip and the waste gate spring. Says the chip alone brings it up to 280 HP. I find that hard to belive?? I know nothing about Audis though. I know it is a fast car but I really want to hand him his ass and I am willing to pay for it. That car is heavy and it has 290 000 km on it. Very well maintained though, synthetics since new.
265000KM
Calgaryturbo
I know you had a tleg DLC what king of horsepower do you think you had after all your mods??
265000KM
91White-T
Post by 91White-T »
No way a chip and higher boost will add 70hp. Hes probably got about 250chp, that car runs high 14s stock though according to this: http://autos.msn.com/research/vip/spec_ ... ab=2&sub=1 , which means you have a lot of work to do since a stock TW will be lucky to hit 16 flat. I would say 3" exhaust, big IC, and a 16g should make it very close. Run high boost if you just care about winning and not longevity.
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Calgaryturbo
Found out the chip is a stage 2 MTM HOPPEN with dual maps one for 91 ocatne and one for 94. Will max oy at 23psi on overboost with 94 octane.
265000KM
azn2nr
Post by azn2nr »
you dont stand a chance without a new 5 speed tune adn major mods. 4eat will only do 16's even with turbo exhaust boost and cooler
-jason
Calgaryturbo
here is the link to the chip he has
http://www.hoppenmotorsport.com/20vtuning.htm
he has the stage 2
265000KM
dzx
Post by dzx »
That's a damn expensive chip.
Touring wagon means you have an automatic. It depends on how much money you have. For budget, i'd go with a 16G from a jdm wrx, a wrx tmic, TBE w/ performance downpipe, safc from ebay and maybe hunt around for an apex'i ITC, they are getting kinda hard to find but it makes a huge difference. With that, you should be able to run 16psi without too much of a problem. Then get cams later on.
///M
rallysam
Post by rallysam »
legacy92ej22t wrote:If you want to beat a 300 chp car it's going to require some pretty extensive mods.
ding ding ding. I vote Matt's comments the most useful in this thread.
Seriously, lots of people on this board have a TBE, WRXIC, and 16G and stop the clock all over the 15's. Stock WRX's walk away from that setup.
heads, intake manifold, fuel system, engine management, big turbo...
'00 Impr RS - sold
professor
Post by professor »
wait for the Audi to break down, and then drive down his steet and wave to him on the way by :-D
based on my experience, you won't be waiting long
dzx
Post by dzx »
If i remember correctly, the ones that actually ran the 1/4 mile were having problems at the time.
///M
Calgaryturbo
It will also depend on if he is willing to drop the clutch or not. The Audi's is original.
I have been considering the 5mt swap but after reading everything It sounds pretty complicated.
Not sure where to find a turbo tranny that is in good shape either.
Greg
265000KM
rallysam
Post by rallysam »
dzx wrote: If i remember correctly, the ones that actually ran the 1/4 mile were having problems at the time.
I don't think so. But, I would like to be wrong, so let me know if I am.
The episode I am speaking of is a couple months ago. The cars I am speaking of are Phil, Matt, and Vikash. Admittedly, Phil was runnning low boost (9psi?). But I think Matt and Vikash's cars were more or less in good shape - high boost with few of the normal fuel cut problems.
I think Phil was the only one to dip into the 14's and a stock '06 rex was teh fast4r
Don't get me wrong, their cars are great and I wish mine was as cool. But I am just saying that it takes a LOT MORE than the basics to make the kind of power this guy is talking about.
'00 Impr RS - sold
wiscon_mark
Post by wiscon_mark »
Matt has been having problems with the knock sensor, and his timing is retarded (no pun intended).
185,000 miles
tonflo
Post by tonflo »
For what you're going to have to spend just for bragging rights, is it really worth it? Use the $ toward an Sti or something.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
91White-T
Post by 91White-T »
tonflo wrote:'99 Zanardi NSX. All stock & ready to rock.
:shock: is that the TW's replacement??
tonflo
Post by tonflo »
Hi 91 white-T. Not replacement, just my dream machine. My Subaru is being a pain lately. Maybe it's mad from having to stay outside all the time now since I only have a 1 car garage.
'05 Corolla XRS
