Page 1 of 3
How to beat a 94 Audi S4?
Posted: Thu Nov 03, 2005 8:19 pm
by Calgaryturbo
My bud just purchased a 1994 S4. It is chipped and he claims it has over 300 hp. He has been talking so much shit lately about how fast this car is so we are going to meet at the track in the spring. I have some money to dump into the tleg now so how do I get enough hp to beat him in the quarter mile and send hime home with his tail between his legs?? I know this thing is fast but also heavy. 300lb
Posted: Thu Nov 03, 2005 8:26 pm
by legacymax
Frankenstien Engine 22t/25sohc.
Posted: Thu Nov 03, 2005 8:28 pm
by Calgaryturbo
you mean changing the heads to 2.5?
Posted: Thu Nov 03, 2005 8:50 pm
by 555BCTurbo
bigger turbo, more boost, and a perfect power...
Then you should be good to go
Posted: Thu Nov 03, 2005 9:03 pm
by Calgaryturbo
whats a perfect power? Engine management?
Posted: Thu Nov 03, 2005 10:08 pm
by Calgaryturbo
I will do the intercooler this week (saab) , turbo back exhaust, and then a bigger turbo. Any suggestions for the turbo? Do I have chance with these mods ?????? The car is fast now only spooling up to 10 PSI. It hase been maintained very well concidering the milage...
Posted: Thu Nov 03, 2005 10:25 pm
by legacy92ej22t
If you want to beat a 300 chp car it's going to require some pretty extensive mods.
Do a bigger i/c then the Saab. The Saab is good for around 250 chp worth of mods max. Even the wrx tmic is probably going to be far too small. I'd go with a nice fmic setup.
For a turbo you'll want to go with a monster 16G, Super 16G or maybe even an 18G.
You'll need a full TBE. Bigger injectors like usdm sti 550cc yellows (at the least) in 92-94 NA rails. Some type of EM (engine management) and probably a built tranny.
Now your car is a lot faster so you'll probably want to upgrade your brakes and suspension so you can control the power, too.
If you're pushing over 300 chp then you'll probably need some head work and should think about a built short block too.
All this won't be cheap. Not cheap at all.
Don't think that you can just throw an exhaust, an i/c and a big turbo on your car and go beat a 300+ chp S4. It won't happen.
Perfect Power is a piggy back engine management system offered by RalliTek.
Posted: Thu Nov 03, 2005 11:10 pm
by dzx
I knew i was missing something.
Posted: Thu Nov 03, 2005 11:14 pm
by DLC
Your car, stock, is going to be much lighter than his. A stock 94 S4, with the turbo'd I-5, weighs just over 3800lbs. Your TW should be around 3300lbs if it's still running the 4EAT. Both are AWD, but he may have the advantage of a transmission that'll use less of that power, being a 5MT.
BTW, the 94 was 230 @ the crank. If you can get an idea of what his mods are, we might be able to make a better estimate than he has.
Posted: Thu Nov 03, 2005 11:26 pm
by Calgaryturbo
all he has done is the chip and the waste gate spring. Says the chip alone brings it up to 280 HP. I find that hard to belive?? I know nothing about Audis though. I know it is a fast car but I really want to hand him his ass and I am willing to pay for it. That car is heavy and it has 290 000 km on it. Very well maintained though, synthetics since new.
Posted: Thu Nov 03, 2005 11:28 pm
by Calgaryturbo
I know you had a tleg DLC what king of horsepower do you think you had after all your mods??
Posted: Thu Nov 03, 2005 11:45 pm
by 91White-T
No way a chip and higher boost will add 70hp. Hes probably got about 250chp, that car runs high 14s stock though according to this:
http://autos.msn.com/research/vip/spec_ ... ab=2&sub=1 , which means you have a lot of work to do since a stock TW will be lucky to hit 16 flat. I would say 3" exhaust, big IC, and a 16g should make it very close. Run high boost if you just care about winning and not longevity.
Posted: Fri Nov 04, 2005 12:34 am
by Calgaryturbo
Found out the chip is a stage 2 MTM HOPPEN with dual maps one for 91 ocatne and one for 94. Will max oy at 23psi on overboost with 94 octane.
Posted: Fri Nov 04, 2005 12:44 am
by azn2nr
you dont stand a chance without a new 5 speed tune adn major mods. 4eat will only do 16's even with turbo exhaust boost and cooler
Posted: Fri Nov 04, 2005 1:22 am
by Calgaryturbo
here is the link to the chip he has
http://www.hoppenmotorsport.com/20vtuning.htm
he has the stage 2
Posted: Fri Nov 04, 2005 2:06 am
by dzx
That's a damn expensive chip.
Touring wagon means you have an automatic. It depends on how much money you have. For budget, i'd go with a 16G from a jdm wrx, a wrx tmic, TBE w/ performance downpipe, safc from ebay and maybe hunt around for an apex'i ITC, they are getting kinda hard to find but it makes a huge difference. With that, you should be able to run 16psi without too much of a problem. Then get cams later on.
Posted: Fri Nov 04, 2005 3:28 pm
by rallysam
legacy92ej22t wrote:If you want to beat a 300 chp car it's going to require some pretty extensive mods.
ding ding ding. I vote Matt's comments the most useful in this thread.
Seriously, lots of people on this board have a TBE, WRXIC, and 16G and stop the clock all over the 15's. Stock WRX's walk away from that setup.
heads, intake manifold, fuel system, engine management, big turbo...
Posted: Fri Nov 04, 2005 3:50 pm
by professor
wait for the Audi to break down, and then drive down his steet and wave to him on the way by
based on my experience, you won't be waiting long
Posted: Fri Nov 04, 2005 6:03 pm
by dzx
rallysam wrote:legacy92ej22t wrote:If you want to beat a 300 chp car it's going to require some pretty extensive mods.
If i remember correctly, the ones that actually ran the 1/4 mile were having problems at the time.
Posted: Fri Nov 04, 2005 7:14 pm
by Calgaryturbo
It will also depend on if he is willing to drop the clutch or not. The Audi's is original.
I have been considering the 5mt swap but after reading everything It sounds pretty complicated.
Not sure where to find a turbo tranny that is in good shape either.
Greg
Posted: Fri Nov 04, 2005 8:55 pm
by rallysam
I don't think so. But, I would like to be wrong, so let me know if I am.
The episode I am speaking of is a couple months ago. The cars I am speaking of are Phil, Matt, and Vikash. Admittedly, Phil was runnning low boost (9psi?). But I think Matt and Vikash's cars were more or less in good shape - high boost with few of the normal fuel cut problems.
I think Phil was the only one to dip into the 14's and a stock '06 rex was teh fast4r
Don't get me wrong, their cars are great and I wish mine was as cool. But I am just saying that it takes a LOT MORE than the basics to make the kind of power this guy is talking about.
Posted: Sat Nov 05, 2005 12:27 am
by wiscon_mark
Matt has been having problems with the knock sensor, and his timing is retarded (no pun intended).
Posted: Sat Nov 05, 2005 6:43 am
by tonflo
For what you're going to have to spend just for bragging rights, is it really worth it? Use the $ toward an Sti or something.
Posted: Sat Nov 05, 2005 3:20 pm
by 91White-T
tonflo wrote:'99 Zanardi NSX. All stock & ready to rock.
is that the TW's replacement??
Posted: Sat Nov 05, 2005 7:12 pm
by tonflo
Hi 91 white-T. Not replacement, just my dream machine. My Subaru is being a pain lately. Maybe it's mad from having to stay outside all the time now since I only have a 1 car garage.
