ECU question EJ22T
1-3-2-4
ECU question EJ22T
I'm looking at the Pinout for the Legacy and I'm looking at the ECU for my 95 Impreza.
My VSS for the Impreza is E29 Pin 4
For the Legacy it's B58 Pin 11 Ok...
What has me a little confused is if I'm pulling my impreza engine harnless wires out from the EJ18 and putting the Legacy one's in Why would I need to work do hard in to finding the correct pinouts?
yes I understand some items on my car depend on the ECU and it's not direct on the engine. Like the VSS...
Having said that I was told I would need the Schematics for both cars?
your trying to do two things at once here.
if your swaping over the legacy motor and harness you shouldnt need the pinouts and the wiring should be fairly stright foreward with the exception of the dashboard.
if your not swapping the harness than you need the pinouts.
-jason
now im really confused. there shouldnt be anything thats not motor related thats on the ecu. if your swapping the harness than it shouldnt matter.
btw can you send me the 1.8 pinouts. ive been looking for them
-jason
well i understand the 2 ways to do this swap and from what i can desipher hes trying to do both ways at the same time.
1234, if your gonna use the legacy harness and the legacy ecu and the legacy motor, there is no need for the 2 sensors you mentioned. just the ones that the legacy ecu uses. for example, youll need the legacy maf map and presure exchange ect ect.
edit to be helpful, you need factory knock sensor, maf sensor, map, pressure exchange, and boost control solenoid. bascily the knock sensor is under the manifold, you should know where the maf is and youll need all that stuff thats on the passanger side strut tower. all these will work with the legacy harness and ecu, if you use a maf that is not for the legacy you need to make sure that it will work with the legacy. some are missing a few wires, 3 to be exact.
-jason
i understand man... im in the middle of this swap right now.
i am NOT using the legacy harness... instead im using my 1.8L harness since it plugs into mostly everthing, then i cut the wires from the 1.8 ecu, carefully labeled them of course, and ill solder the ones that correspond onto the legacy ECU connectors. the ones that dont match up are taken care of individually, and all the boost stuff i pulled from the legacy harness, and LEFT it connected to the leg ecu so i dont have to re solder those ones on too.
1-3-2-4... if you havent, you need to check out my thread on nasioc "Rewiring my EJ22T" in the conversions forum
one thing i need to figure out is the ignition.... it looks like it should work, but vrg3 says i need to take care of something else, ill look into that.
-nathan
-nathan
huh? like out of the ecu?
vrg- there are a couple things on the legacy ECU that have their own grounds, but on the 1.8ecu all ground in the same thing... can i just ground them all in the same place on the one wire? i assume so since they are just grounds.
about that self shutoff thing... the impreza you were talking about in that thread did it not have self-shutoff so you told him how to get around it? because mine DOES have self shutoff (mine is a 95, OBD "I-1/2") and all the wires match up, but it still wont work?
thanks
thanks
Out of the harness, not the ECU.
Are you talking about the sensor grounds? Yeah, joining them should be fine... make sure you're aware, though, of which ones are grounds provided by the ECU and which ones are provided to the ECU.
All Imprezas have self-shutoff.
yeah im talking out of the harness connectors. if you go get the harness plugs from the junkyard and pull all the pins out. then carefully do the same on the 1.8 harness and mark them then repin them into the empty harness plugs you wouldnt have to soder so many wires. not to say you elminate sodering but you take care of alot of it.
-jason
well actually... there arent really many plugs i need to change over in the engine bay. cam and crank sensors match up, injectors do of course, even the IAC does, 02 does, TPS and MAF are the only things i have to change over, but the maf im running straight to the ECU ( i left it all connected and ran it through the firewall) so really just the TPS i need to add a wire.
1-3-2-4
Sorry, I got so tied up in finding the front rotors for me car, Only for them to give me the Wrong rotors at 2 Auto stores!!
they both gave me rear rotors when I asked for Front rotors, so I pretty much been running around since 9Am this morning, I will give them a call tomorrow, I take it you want to know about the Ej22T as well?
On the upside I FINALLY picked up a Hanyes Subaru Legacy repair manual, lol I've picked it up so many times to read it in the store, but I finally got it today, pretty helpful, and helpful come time of the swap.
crap, i believe THIS may be my problem now, how can i tell the difference between grounds provided to the ECU and ground provided by the ECU...?vrg3 wrote:Are you talking about the sensor grounds? Yeah, joining them should be fine... make sure you're aware, though, of which ones are grounds provided by the ECU and which ones are provided to the ECU.
sensor ground, injector ground, and main power ground are the only ground provided to the ECU, and then individual sensor grounds are provided by the ecu? but i can ground them all to the body to make sure cant i?
