CE light code, semi-n00b question
Turbo Tony
Post by Turbo Tony »
Apologies in advance if this is out of place, or out of line. I've been snooping around since picking up my 99 Legacy Outback wagon this summer and now have a reason to post. Anyway, I had a CE light for a couple hours tonight in the Suba. The light went out (after filling the gas tank funny enough) so I pulled the stored code with an OBDII logger (I'm an old school DSMer, thus, used to problems). Here's the code:
PO 325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
I copied that verbatim from the logger screen. If anyone here has a base of knowledge re: CE lights, and could let me know if this is other than what it so obviously appears to be (bad knock sensor). Also, let me know if this is a simple job for the enthusiast with appropriate tools, or something much more exquisitely painful.
Thanks guys (and girls?)
napphappy
Post by napphappy »
Its not enjoyable, but not all together difficult.
There is only one and its located on the top of the block between the throtttlebody and the EGR stuff on the #4 intake runner. One bolt holds it on. Its donut shaped with a single wire.
Replace it.
Hope that helps.
I'd recommend resetting the ECU, and see if the code comes back. If it comes back, then replace it.
