Check these wheels out?
Calgaryturbo
Post by Calgaryturbo »
http://www.buysell.com/root/detail/BC/C ... roxes.aspx
Anyone know if these will fit? Read through a bunch of threads and can't see anyone running 225's . I suspect that they might rub.
If they fit I will have a set of 15's for sale from my touring wagon.
Greg
1993 Silver Touring Wagon ,Saab IC, 15 PSI ,MBC, Boost Guage, Ground mod, desnorkified, K&N ,Custom exhaust,
265000KM
legacy92ej22t
Post by legacy92ej22t »
Phil was running 17x7.5" Rotas iirc. HE rolled his fenders and still got minor rubbing during spirited cornering.
In terms of offset, I think 48 is good but someone else that knows for sure might chime in.
You might want to check SubieDude if you're into Rotas. He usually has them cheap.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Post by BAC5.2 »
I have some 17x7.5 Sub Zero's (ET48) with 225/45/17 RE070's.
They rub a little, and eventually I'll fix it. You will HAVE to roll the fenders.
