The moral? Don't trust what others have done to car, especially when you know it's not right! Duh! Should've known!
Moral #2? Stay away from Wal-Mart. This had to have been their fualt, somehow!
If this is the case then you shouldn't install a device that is capable of starting your vehicle if you are not behind the wheel. Most vehicle remote starter makers advise you not install such devices on cars with manual transmissions.vrg3 wrote:Trusting the parking brake alone to hold the car is irresponsible. An incline isn't the only thing that can affect a parked car. It's not very hard to move a car with the handbrake engaged, even if the handbrake is in tip-top shape. And of course, the handbrake does wear -- the shoes and the cables both.
You're supposed to always put the transmission in park (automatic) or in gear (manual) when you park the car.
I dare you to try to move my car with the e-brake on. I doubt you'll even be able to budge it.vrg3 wrote:Trusting the parking brake alone to hold the car is irresponsible. An incline isn't the only thing that can affect a parked car. It's not very hard to move a car with the handbrake engaged, even if the handbrake is in tip-top shape. And of course, the handbrake does wear -- the shoes and the cables both.
