EJ20T Q's and A's
Locked
poseidon1787
EJ20T Q's and A's
Post by poseidon1787 »
hey whats up everyone i got some q's that i hopefully could answer, i am wanting to put an ej20t in my 91 legacy, i was wondering is that a good swap for that car, will i neeed the ej20t harness and ecu?? or can i usae the stock ej22e harness and ecu, my legacy used to be AT it is now a MT ,but it still has its auto ecu , also i might get one from a place called nippon motors, located in california, the motor comes without a turbo is it worth 650.00 dollars??, has anybody ever heard of theis place?? also i need to know if there are ne turbos that i can get for cheap that will do a direct bolt up to the stock manifold, or should i just go to the junkyard by my house and pick up the EJ22t thats sitting in an old touring wagon?? thanks for the help!
napphappy
Post by napphappy »
The ej20t from nippon is really an ej20g. Nippon sells ALOT, but I have never done bussness with them. you will need a turbo harness and ecu. I would get the harness and ecu off the touring wagon at the JY. You might see if nippon has a turbo you can buy.
Where are you located?
napphappy
Post by napphappy »
you can use the EJ22t harness if you use the Ej22t ecu, and switch the Ej20g to wasted spark, instead of coil-on-plug. I believe there are several members who have done this. Although it will be considerable more difficult to put all this in a N/A legacy.
If I were you I would see if the JY would make you a package deal. You will need the pressure sensor assembly and the cross-member. As well as the harness, so you might as well buy everything an sell what you dont need.
Just a though.
Matt Monson
Post by Matt Monson »
damn,
couldn't you just start one thread for all of this? Where's a moderator to give out a warning when you need one.
JASON?!?!?!
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Post by 555BCTurbo »
I have a spare T-Bird Hybrid turbo that I might be able to part with if needed... Has zero shaft play, and is good to 14-15 psi
napphappy
Post by napphappy »
Ditto Matt
P.S. I found almost all the info I needed to do my swap by SEARCHing. All the info is out there, it just takes some digging.
Please continue all comments regarding your swap in this thread
http://bbs.legacycentral.org/viewtopic.php?t=24246
Locked
