How much noise can a wheel bearing make???
I am thinking about buying a gen1 legacy but the guy says it is making a loud noise from the front end and thinks it's a bearing.
LAst time I bought a legacy where the owner said it needed a bearing, it turned out to be a SHOT tranny.
Any advice from the GUROOS would be greatly appreciated.
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
They can be pretty damn loud. However, the noise you're looking for is a grind or roar from a specific area of the car. And really, the easiest way to check is to jack the car up and try to shake each of the wheels. The one that shakes (ones with a good bearing will not move laterally) has a wheel bearing issue.
The car is about 600 miles from me and the guy refuses to inspect it in any way shape or form. His mechanic just drove it around the block and said "I was told that it has a front bearing bad ( MAKES A BAD NOISE IN THE FRONT )"
Think it will make a 600miles trip on a bad bearing? If so I will just change the entire hub assembly out when I get it home.
My dad drove my car 10k miles on a bearing that absolutely ROARED. Now, granted that wasn't a good idea. I would only be afraid of it seizing. 600 miles...I think it'll make it...just keep your cell with yousubawhatsubawho wrote:The car is about 600 miles from me and the guy refuses to inspect it in any way shape or form. His mechanic just drove it around the block and said "I was told that it has a front bearing bad ( MAKES A BAD NOISE IN THE FRONT )"
If it's a deal, I'd risk it. It'd have to be pretty damn bad for me to not wanna take the risk.
I drove my wheel bearing until there was nothing left, then had to go get the truck and load the car on the trailer and tow it home. When i removed the hub, the wheel bearing looked like a washer and that's all i found of it. I just pulled a hub off of a car at the junkyard and replaced the whole thing.
///M
'93 Legacy SS - part out
- quasi-mod-o
Up to this point, I'd say that this thread is the most thorough wheel bearing thread on this board (not to say that someone couldn't do it better, faster, or cheaper than me...)
http://bbs.legacycentral.org/viewtopic.php?t=21223
I remember when you posted that thread. I remember reading your trials and tribulations.....
If I do end up purchasing this vehicle I am just going to swap out the front assembly from something much newer.
Thanks for the link Mike. I read it again anyways.
Isn't that when you gave Patti a fresh dent with a pipe?subyluvr2212 wrote:Up to this point, I'd say that this thread is the most thorough wheel bearing thread on this board (not to say that someone couldn't do it better, faster, or cheaper than me...)
- quasi-mod-o
Sure is... I'd rather take a cutting torch to her right now...Manarius wrote:Isn't that when you gave Patti a fresh dent with a pipe?subyluvr2212 wrote:Up to this point, I'd say that this thread is the most thorough wheel bearing thread on this board (not to say that someone couldn't do it better, faster, or cheaper than me...)
