Help Code 22!!
Sk3oSH
Help Code 22!!
Post by Sk3oSH »
i have a 22 CEL and i need some advice on what might be the problem. the car seems to idle and run fine, though its alil shaky at idle and do to the retarted timing it really doesnt feel like when i was new. do you think that maybe its just the knock sensor thats gone bad or is my car just knocking. i dont hear any audible sign, though my car is loud. the car has 200k miles and i already fixed a code 35 boost solenoid. i really hope its just the sensor, but if not what r my options? has anyone else run into this prob?
thanx
-Danny
If it's still the original knock sensor, it's probably got cracks and it's shorting out or just not working correctly.
They have come out with a new design. I'd suggest replacing the sensor, resetting the ECU, and see if that fixes your problems.
gt2.5turbo
Post by gt2.5turbo »
ah yes those little knock sensors... i think ive had to replace it on every legacy that ive owned
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
Sk3oSH
Post by Sk3oSH »
Legacy777 wrote:If it's still the original knock sensor, it's probably got cracks and it's shorting out or just not working correctly.
where can i get one of these new ones? is there a better type to get than OEM? i was going to get it from NAPA tomorrow but if theres a better kind ill go for that. can it be had cheeper online? thanx
https://www.subarugenuineparts.com/oe_parts_cat.html
Part # is 22060AA031
It's $66.37
I doubt you'll be able to get it at napa. I'd recommend getting the subaru part.
