Reverse lights
MY92
Reverse lights
Post by MY92 »
Ok, I have checked my reverse lights up to the plug that goes to the gearbox. If I cross the wires there they light up, so I'm assuming it is the reverse sensor in the gearbox.
Does anyone know how much drama it is to change it? Hopefully I can just unbolt it and bolt in a new one?
John
http://www.cardomain.com/ride/560635
Yeah, you should be able to remove the old sensor and put in the new one.
Post by BAC5.2 »
Yep. I think it's a 19mm. Use an open ended wrench.
It's easier to do if you unplug the sensor first and remove the clip from the top of the transmission. It's easier to turn and get it off.
To do this, drive around for a while, get the transmission warm. Then let the car sit for a while so the transmission fluid can settle. Then just pull the sensor and replace it. THIS is probably the easiest car maintainence gets.
MY92
Post by MY92 »
Thanks for the tips guys.
Definatley going to unplug it all before I unbolt it.
John
