yet another heads thread.
azn2nr
Post by azn2nr »
the final frontier for swapping heads is the wireing. so i ask which heads can be wired into the ss harness.
so which sensors are on the heads that the ecu needs. which of these sensors are different on each head. are there more teeth on the cam gears ect.
asuming the use of a coil pack and full top end swap for bolt up purposes of course.
-jason
There really aren't any sensors on the heads themselves. The cam pullies can be swapped, and I don't think there is any difference anyway.
