all i need for the swap??
poseidon1787
ok so this is this what i need, harness, ecu, maf,injectors,boost control solenoids,pressure sensor,pressure exchange solenoid, all from an ej22t? i know i need the motor too but is this a total CORRECT list of what i need??
Sounds about right. Just use your n/a radiator. I ran the overflow from the radiator into the line that ran across the top of the intake manifold. I took the rubber off the radiator cap (the one that goes on the radiator) so fluid could flow between it and the overflow tank.
tris91ricer
- Title Whore
What is swapping from again? Refresh, please.
Your ebrake handle will need to be swapped, too, I imagine. Reason being that the wire connectors are different.
How far are you taking the car down? Are you swapping the entire harness? If so, I'd suggest zip ties, as we'll, I used PLENTY of them in making the wires go back to their normal spot, and also, to help clean up the routing of them. If they're altogether, they're easier to put into place.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
EJ20g 4.11 5sp LSD
[/quote]
You really don't need an entire harness to do the swap.
tris91ricer
- Title Whore
