These are the question's:
1. I have the money to do this swap. The parts I have found for it are these for the swap--- R180 LSD--- 5MT AWD trans from 93-94 legacy--- Full rear cross member from a 94 all wheel drive model.
2. I know about needing axles and the hubs and I know they will fit together to an extent.
3. THIS IS IT
I know RWD is a lame swap to a 94 legacy sedan, but hey. how many people do you know with a RWD legacy sedan? I thought so...
It came as a factory 2WD so why not keep it that way and make something that will be on the same level as a GTS-t R32... Or something compareable i guess.
Thank you all for your helpful posts in the past when i had my wagon! You people are great!
Happy Times!
Ben
