If I were to completely bypass the current fuel system, and essentially switch to running a carburetion system(via an lpg mixer), would the factory ECU still handle the timing duties? I would keep the MAF, although possibly reconfigure to a blow through MAF, using a draw through mixer(lpg vapour running through the turbo, and MAF). I guess the main question is would the engine run without the injectors running as long as it still got adequate fuel. I'm not looking for an ideal situation, just one in order to get a baseline and then tune the lpg system to work with the rest of the factory stuff. Writing this out really makes this sound like a rediculous question, but I still want anwers and opinions.
