Pin outs for a 94 BC do not exist
Hi all have searched high and low and even called my subaru pall in georgia and the pin outs for a 94 NA BC do not exist so does anyone know of any afc options that dont require the pinouts? just in case from left to right I have a 16 12 20 pin on my ecu please some one prove me wrong!!! and yes I have posted on Nasioc and wrxtunners and have found that legacy guys and gals are truely the brightest out of the subaru bunch
You're looking at the TCU -- the goldish colored box under the steering column with black connectors. The ECU is a little over to the left and towards the front of the vehicle. A silver box with four yellow connectors.
Quick question which one is closest to my BC 94 EJ22 with a make date of 93.9 for an apexi s-afc first gen, BG5 BF5 EJ20 89.2-93.10 (curently using this set up), BG9 EJ25D 94.10- 96.6, BD5, BG5 EJ20H or EJ20D 93.10-96.6, the only diference btwn the two is the air flow signal Curently I am using the B48.9 MAF signal and is the B56.16 the right one to use for a rpm signal according to the cornell pin outs? if you go onto the yahoo site they have all the manuals for the afc, cause right now I can not get my car to idle after 30 sec due to the sti yellows I have installed or is it another problem? and fixes
Uh, what?
I'm having a little trouble understanding what you're asking...
My pinouts are correct for your car. B48.9 is the airflow signal and B56.16 is the RPM signal.
So you put in STi injectors and an AFC and now your car won't idle?
