Urgent help needed with tranny swap
gt2.5turbo
Post by gt2.5turbo »
K well im installing a rs tranny and running into some snags...
1. Im wanting to do cable clutch, and i know that a few of you are running this setup, but what fork did you use cause i pulled a 93 5MT fork and it doesnt reach the throw out bearing so what did you do?
2. THe RS had an electronic speedo... how did you convert to cable? do they just interchange? and it doesnt look like the cable is long enough to reach its new location
3. did the 96 legacy L 5mt have a 4.11 ratio?
gt2.5turbo
speedo thing figured out i think unless someone knows how to make th AT one reach
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
I replied to your other thread on nasioc. Did my recommendation suggestion work?
gt2.5turbo
ya i they helped thanks again. the speedo cable actually ended up being able to reach. Had to deal with a starter issue and right after dinner in about 15mins i need to solve the issue with the driveshaft not mating up with the rear dif right... hopefully the swap will be complete late tonight/ tomorrow afternoon
