engine code 31
engine code 31
after my tranny swap everything went fine except im now throwing code 31 which i think is TPS voltage maxing out or something along those lines. any thoughts? im pretty sure everything is plugged in anything i should look for?
31 is just abnormal voltage. Have you tried resetting the ECU or measuring the voltage at the TPS?
