Intercooler + Boost Gauge
I got my intercooler from nsantos in the mail today, and of course Im itching to install it.
However, my gauge hasnt arrived yet. I should be ok to install the IC and run it on factory boost until the gauge arrives, yes?
rallysam
The only thing you might wish you had the gauge for is to help diagnose a boost leak. But I say go for it.
'00 Impr RS - sold
gt2.5turbo
ya you will probably experience a pressure drop when you install the ic. I went from stock to 5psi with my wrx ic
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
rallysam
If this is the stock recirc valve you're talking about, I thought I read somewhere on the BBS that you shouldn't run it atmospheric because it leaks at idle - ie a manifold leak. If you have problems, then you can search on that one.
'00 Impr RS - sold
I ran it atmospheric to the auto store this morning, and it did come really close to stalling out almost every time I went from boost to idle
I also was losing massive amounts of power at half-throttle, it was stuttering and hestitating like crazy
Its running incredibly well now that I have it hooked up. I havent even turned up the boost yet and there is an extremely noticeable increase in pickup
That's nothing but a locator tab for the SAAB's the intercoolers came in.shemoves wrote:Splinter...is that is on the right side, middle of the IC the open nipple you were talking about? Do you just leave that sitting out in the open?
Just thought I'd update
I've got my boost gauge and MBC in, running 12.5PSI
Pulls like a bastard. It's actually a little tough to drive in heavy traffic, it has a tendancy to surge. I think Im actually going to run a lower boost (than stock) most of the time for fuel economies sake, and just turn it up for spirited driving.
