STI Yellow injectors 480cc for sale AND Ignition coil
waldo320
Post by waldo320 »
Hey all I have a set of 4 yellow sti injectors that flow at 480cc. They are in perfect working conditon all O rings are in great shape. They will fit 92-94 NA fuel rails hence these are side feed injectors. Selling for $225 pm me if intrested or have any questions first come first serve.
I also have an ignition coil off a 91 legacy have no clue how many miles are on it have tested it on my 94 legacy and the wiring harness are the same, and the unit works perfectly. Will sell the coil for 40$ pm me if intrested first come first serve.
93Leg-c
Post by 93Leg-c »
What year sti are they from? Did you test them out on your car? How did they work?
'94 TW
waldo320
Post by waldo320 »
I think they are 04 sti, and yes I have tested them in my car and they work great, but I could not get my afc to work right and thus created a deiseling problem, just going to try to get my car running good and maybe upgrade the injectors latter.
93Leg-c
Post by 93Leg-c »
Thanks for that info. Umm, any reason why you're not keeping them?
'94 TW
waldo320
Post by waldo320 »
I could not get my afc working right is the main reason that I am selling and since I am running only 7psi it is a little over kill, unless the afc is working
I thought the yellow ones were 550's?
subawhatsubawho
Post by subawhatsubawho »
The pinks and yellows are 550's. The only difference is that one is top feed and one is side feed.
IIRC..correct me if I am wrong.
I read that the yellow 99-00 were 440's.
This guy on ebay has JDM yellows and he says they are 480's.
http://cgi.ebay.com/ebaymotors/Standard ... enameZWDVW
1991 Legacy BJ L 5MT AWD 189K Paid $100 STOLEN 2/13/06
waldo320
Post by waldo320 »
they look exactly the same as those on ebay, is there any way to check the injector to see how many cc's.
Fuel pressure.
waldo320
Post by waldo320 »
they all have a number 5 on the top whaterver that means
NICO
Post by NICO »
there is a way to tell, the tips on the 550cc yellow side feed sti injectors are all aluminium tips with 4 or 5 holes of spraying
the other look a like 480cc yellow side feed injectors have a plastic tip at the end and have 2 holes for spraying.
old post but need to give the info out for pepole that are upgradeing there ej22t motor.
Blackbart
Vendor
Vendor
Post by Blackbart »
Is there a chart, or and old thread somewhere, that can help us ID injectors if we do not know where they came from?
