Code 45... Pressure Sensor Duty
hackish
Post by hackish »
I'm getting a code 45.
45 Pressure Sensor Duty Solenoid (Turbo Models)
I wonder if this is the boost solenoid they're talking about. Ring a bell with anyone?
-Michael
No. This code is for either the pressure sensor or for the pressure exchange solenoid that switches the sensor from measuring manifold pressure to measuring atmospheric pressure.
hackish
Post by hackish »
Hm. That makes sense. Does the ECU sample the atmospheric pressure constantly or is it a one time thing? It's experiencing a little hesitation during cruise and I wonder if it's related to bad barometer values. Man I need to figure out the factory triggering scheme.
-Michael
free5ty1e
Post by free5ty1e »
IIRC, the ECU switches the pressure sensor over to atmospheric every few seconds as long as you're not boosting.
-Chris
91SS 4EAT stock, 200k mi
It samples it periodically -- maybe every 30 second or every minute or so -- and also every time you transition from below to above atmospheric manifold pressure.
