Code 45... Pressure Sensor Duty
Posted: Sat Jan 28, 2006 7:19 am
by hackish
I'm getting a code 45.
45 Pressure Sensor Duty Solenoid (Turbo Models)
I wonder if this is the boost solenoid they're talking about. Ring a bell with anyone?
-Michael
Posted: Sat Jan 28, 2006 8:15 am
No. This code is for either the pressure sensor or for the pressure exchange solenoid that switches the sensor from measuring manifold pressure to measuring atmospheric pressure.
Posted: Mon Jan 30, 2006 1:17 am
by hackish
Hm. That makes sense. Does the ECU sample the atmospheric pressure constantly or is it a one time thing? It's experiencing a little hesitation during cruise and I wonder if it's related to bad barometer values. Man I need to figure out the factory triggering scheme.
-Michael
Posted: Mon Jan 30, 2006 1:54 am
by free5ty1e
IIRC, the ECU switches the pressure sensor over to atmospheric every few seconds as long as you're not boosting.
Posted: Mon Jan 30, 2006 2:00 am
It samples it periodically -- maybe every 30 second or every minute or so -- and also every time you transition from below to above atmospheric manifold pressure.
