Sunroof glass w/gasket, $50 plus shipping
Blackbart
Vendor
Vendor
Post by Blackbart »
Sunroof glass w/gasket, fits 90-94, $50 plus shipping from PA 18824
i heart my shagginwaggin
Post by i heart my shagginwaggin »
how hard is it to install or how much to have it installed?
Blackbart
Vendor
Vendor
Post by Blackbart »
You can do it yourself. You have to remove the four plastic rivets, then the eight 10 mm nuts, then push it up. Don't loose the shims. The shims are put in at the factory to seat the glass up into the roof.
You can try to reuse the rivets, but they usually break for me, new ones can be bought at body shops or maybe auto parts stores.
Damon
Post by Damon »
Blackbart, check your pm's :-D
wait its that easy if i dont have a sunroof already?
93 legacy wag. burg. 96XXX. need2modify
Blackbart
Vendor
Vendor
Post by Blackbart »
I think putting one into a car that didn't have one in the first place isn't something I would wanna try, I though you just wanted to change the glass! I am sure it can be done but it would be tough to make the opening look OE without having a donor roof to cut up. All that stuff can be had, I will see what I have. Think you can do it? Can someone MIG it in for you?
92whitelegacy
Post by 92whitelegacy »
BUMP sent u a PM, cause my dumbass cracked my sunroof :(
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
Blackbart
Vendor
Vendor
Post by Blackbart »
You sat on it? :smt042
92whitelegacy
lol, doing that crazy rally shit and somehow i ended up sitting on the sunroof :shock: jp, no it wouldnt open so i gave it a little *tap* and it cracked :(
93Leg-c
Post by 93Leg-c »
Do you still have a moonroof with all mounting hardware available?
'94 TW
Blackbart
Vendor
Vendor
Post by Blackbart »
93Leg-c wrote:Do you still have a moonroof with all mounting hardware available?
Yes
93Leg-c
Post by 93Leg-c »
Does the moonroof glass have a bronze tint like those in the '91 LSs or does it have a blue green tint?
'94 TW
Blackbart
Vendor
Vendor
Post by Blackbart »
Pretty sure it is the blue/green, I can check in the morning.
92whitelegacy
My stocker was blue. Me likey bronze/tan better. :wink:
