Hello everyone, I just wanted to introduce myself... my name is Tony and I"m about to purchase a 92 Legacy L AWD from my sister in law for 700 bucks? Not bad for the price. The car is a dark green with tan interior, five speed, and currently has about 210K miles on her but drives like a freaking new car! I won't be of much help concidering this will be my first Subaru.... so expect a lot of newbie comments from myself
PS: Is there any other members from Idaho?
Hello, new member from Idaho!
Welcome, from Tony in CT. Good luck with the car, lots of info & help here if you need it.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
'05 Corolla XRS
Would probably be a good time to do the water pump, hoses, other belts, idler pulleys, etc. you will have apart or access to at the same time. Some of the cam seals & o-rings too. Check in here
http://bbs.legacycentral.org/viewtopic.php?t=25023
http://bbs.legacycentral.org/viewtopic.php?t=24543
for starters. Use search, you'll find all kinds of stuff. Good luck. I have a bunch of hose part #s if you need them.
'05 Corolla XRS
'05 Corolla XRS
I bought my first Subaru for $500 and have only bought a different make (Mazda 3) since so I needed a car to slam with miles quickly, but also so I could take the Legacy off the road and hot rod it. I still prefer the old wagon. These cars are really well built.
