I'm planning to turbo my XT6 and I have recently picked up a JDM AWIC from early jap legs... I have a few general questions about its operation as far as the extras go. I am Super Junkyard dweller, so you know where I'm coming from on some of my ideas.
First is the pump... I just need a good idea on the amount of flow it needs... I was kinda thinking of using like a fuel pump from an EFI system...I would assume that it could flow pretty good, or if anyone knows where I might attain a descent pump for under $100 as I'm trying to keep this project fairly cheap... or not spend money where its not needed..
Next is the water cooler... A few people have mentioned honda rads... or even oil coolers... what about a heater core? Its compact, and usually more then 1 row.... plus it would have the right size fittings... remember this is going into an xt6 with AC.
Last is the reserve... is an extra tank needed? How much, like a coolant tank or more then a gallon or what.... also what should I use for the fluid... just regular antifreeze/water mix?
Thanks peoples!
