Page 1 of 5
Horsepower gains
Posted: Wed Feb 08, 2006 6:10 pm
by 92BlackBeauty
So what kind of horsepower gains could be expected on my 92 SS if I swap a tdo5h-16g onto it, properly clocked, with a FMIC, and full 3" exhaust with an MBC and an FCD?
Would this be suitable to put me up in the 250-260hp at the wheels range?
Also, what psi is the 16g efficient to? I know several members are running this exact setup, and I would love to hear what they have to say about driveability and off the line power, as well as top end boost.
Posted: Wed Feb 08, 2006 6:41 pm
You need engine management, larger injectors, and JECS MAF sensor to really be able to properly utilize that setup.
Posted: Thu Feb 09, 2006 12:42 am
by dzx
Sounds almost exactly like my old setup. I had the deadbolt 16G and it was very smooth. I remember when i first installed the front mount, turned up the boost and stepped on it. It's very nice, I was a little scared to get on it for a while. I was running stock injectors and stock ecu also at the time. As for off the line, it was murder. There was a lot of power just by launching at 3k rpm.
Posted: Thu Feb 09, 2006 5:09 am
by azn2nr
see theres only one problem with the question posed.
the only peson who has dynoed that setup is phil, and it wasnt exactly like you describe. my setup is exactly how you describe. but i have never been dynoed
Posted: Thu Feb 09, 2006 6:56 am
by dzx
my old setup was exactly that except for 4.11 transmission and other mods and i never dynoed it.
Posted: Thu Feb 09, 2006 9:48 am
by 92BlackBeauty
Well Jason, all I'm really looking for is if this setup will run safely and be reliable, and just looking to see if this is worth doing, and if there is a noticeable increase in power, as I don't ever get trak time, and it would mostly be for night racing meets where the top cars are turbo eclipses and a few integras that think they own the streets.
Posted: Thu Feb 09, 2006 9:51 am
by Splinter
Please dont street race.
Even in my small city of 300,000 we have track days where you can prove who has the bigger pistons.
Posted: Thu Feb 09, 2006 10:24 am
by NICO
your going to need what Legacy777 + a 6mt so you can crunch as fast gears like those cars you listed.
Posted: Thu Feb 09, 2006 5:24 pm
by BAC5.2
The 6-speed sucks for drag racing.
Posted: Fri Feb 10, 2006 3:25 am
by ferrari494
no way, i want the 7 speeds that they have in the fast and the furious...
Posted: Fri Feb 10, 2006 3:30 am
by evolutionmovement
I want the 10-speeds they'd have been better off riding!
Posted: Fri Feb 10, 2006 7:24 am
by azn2nr
92BlackBeauty wrote:Well Jason, all I'm really looking for is if this setup will run safely and be reliable, and just looking to see if this is worth doing, and if there is a noticeable increase in power, as I don't ever get trak time, and it would mostly be for night racing meets where the top cars are turbo eclipses and a few integras that think they own the streets.
mostly because they do. dont try to fuck with dsm's as they make gobs of power on little modification. and unless you have a manual you dont even stand a chance. imo of course.
Posted: Fri Feb 10, 2006 7:26 am
by Splinter
How about a CVT
Posted: Fri Feb 10, 2006 9:16 am
by 92BlackBeauty
I am definitely rolling a standard, and word is that the stock tranny is pretty tough. The DSM cars here aren't really too heavily modified, honestly you would be pressed to find a front mount intercooler on one of them. I'm positive that I could pull faster quarters than those fools.
Posted: Fri Feb 10, 2006 10:07 am
by NICO
the legacy turbo 5mt is strong but it does not let you change gears as fast as the dsm's.
first to second is a bitch, if you really want when i race these dsm's i start in second gear and burn my clutch.
i ONLY do this when i see a real fast dsm's, fast as in he peels out in a awd from the hole
Posted: Fri Feb 10, 2006 2:23 pm
by sammydafish
I gotta side with the other guys here... DSMs are no joke, they can find themselfs dipping into the 12s with mostly home depot mods and a good driver.
for the rest of you guys, you never ran in the 1/4? 1/4 mile trap speed is a pretty good way to estimate horsepower. Since most people run without a spare and only 1/4 tank of gas, that pretty much makes up for driver weight so you can use the published curb weight for the calculation. I've done this, then strapped to a dyno a few times and have never been off more than about 10 horsepower.
Posted: Fri Feb 10, 2006 5:58 pm
by BAC5.2
92BlackBeauty wrote:I am definitely rolling a standard, and word is that the stock tranny is pretty tough. The DSM cars here aren't really too heavily modified, honestly you would be pressed to find a front mount intercooler on one of them. I'm positive that I could pull faster quarters than those fools.
Who's word? Myself, Matt, and Vikash have all blown our transmissions recently.
Posted: Fri Feb 10, 2006 6:05 pm
by dzx
bahahaha suckers.
j/k
Posted: Sat Feb 11, 2006 8:00 am
by 92BlackBeauty
Wow, then I guess the DSM's will rule until I get back from the rigs.
Posted: Sat Feb 11, 2006 8:45 am
by Kelly
BAC5.2 wrote:92BlackBeauty wrote:I am definitely rolling a standard, and word is that the stock tranny is pretty tough. The DSM cars here aren't really too heavily modified, honestly you would be pressed to find a front mount intercooler on one of them. I'm positive that I could pull faster quarters than those fools.
just replaced mine too.
Posted: Sat Feb 11, 2006 10:08 am
by NICO
wow all these broken trannys brings me way back in time, im telling you guys make sure you put in basic gear oil 80w90. change it 2 or 3 times a year and it will last for ever, even if your makeing more power.
dont use sythetic rally crap addtives or what ever there is out there that thinks it will HELP out no no no no no, 80w90 basic gear oil thats it.
i have 400,000kms on the tranny with useing basic factory spec gear oil, and you all no i am makeing huge power.
Posted: Sat Feb 11, 2006 10:12 am
by NICO
i have 400,000kms on the tranny with useing basic factory spec gear oil it hasent broken yet, and you all no i am makeing huge power.
Posted: Sun Feb 12, 2006 2:12 am
by Psychoreo
^ nico's car is so hot.
you won't hit 250-260 without more fuel and better EM, and a propper tune of course.
Posted: Sun Feb 12, 2006 4:21 am
by NICO
Psychoreo wrote:^ nico's car is so hot.
thank you sirrrrrrrrrrrr.
Posted: Sun Feb 12, 2006 9:53 am
by 92BlackBeauty
Yes Nico I believe it was a picture of your red legacy with the massive front mount that made me choose to buy a legacy in the first place. For those of you running exactly the setup I described, with no engine management or beefed up injectors, how does it run? Is it worth the money and effort spent in terms of power increase?
