Rotating picture submissions
DLC
Post by DLC »
Ok, so most of you have noticed the rotating images in the top left corner. It's been suggested that we allow people to submit personal car images for inclusion in this rotation. I'm going to give it a try, and the first 25 people to post their images to this thread will get put into the rotation.
Here are the rules:
1) jpegs only, no .gifs
2) Image dimensions no larger than 250w x 130h
2) Image size no more than 15kb
4) Your name/nick in the bottom left or right of the image
5) Image does not have to be a Legacy (but c'mon)
The first 25 images to meet these requirements by whenever will be put into the rotation.
Running tally of qualified entries:
  • 1)Image
    2)Image
    3)Image
    4)Image
    5)Image
    6)Image
    7)Image
    8)Image
    9)Image
    10)Image
    11)Image
    12)Image
    13)Image
    14)Image
    15)Image
    16)Image
    17)Image
    18)Image
    19)Image
    20)Image
    21)Image
    22)Image
    23)Image
    24)Image
    25)Image
Admin Entries:
jamal
Vendor
Vendor
Post by jamal »
Cool.
All those other ones are in this folder
DLC
Post by DLC »
I clarified the first post. I'd like images of personal cars for inclusion into the rotation.
jamal: if you can send me copies of those images, non-personalized, I'll include them as well.
smartDark is the default theme, so it's the most used one. It's what I do any changes on, so i make no guarantee that other modifications will make their way to other themes.
Legacy Central
JC
Post by JC »
15kb is really small, can you bump it up to like 20 or 25k?
[url=http://img254.echo.cx/img254/5309/pond8fq.jpg]2000 2.5RS[/url]
jamal
Vendor
Vendor
Post by jamal »
okay well that makes a lot more sense. Editing my post.
DLC
Post by DLC »
All of the current images but one are 15kb and below, with half of them smaller than 10kb, so that's what I'm basing that off. They don't need to be high quality, so it shouldn't be a problem to get them down.
It might be a good idea to post up multiple versions, one at about 15kb and one between 20-25kb, so we can judge whether or not it's arguably superior.
Legacy Central
Need to dust off photoshop....
jamal
Vendor
Vendor
Post by jamal »
DLC wrote:All of the current images but one are 15kb and below, with half of them smaller than 10kb, so that's what I'm basing that off. They don't need to be high quality, so it shouldn't be a problem to get them down.
All the ones I made were at between 65-75 quality in photoshop, which is about as high of quality and you can get while "saving for web." I think it looks fine. For comparison, here's my 15k image compared to one saved at "maximum quality," which works out to be 52k. I can't see much of a difference.
Dave wrote:1) jpegs only, no .gifs
The first 25 images to meet these requirements by 16th will be put into the rotation.
Is that a promise? :)
http://www.graphics.cornell.edu/~v/pics/vrg3.jpg
92whitelegacy
Post by 92whitelegacy »
Im intrested VERY intrested *saves spot* I'll try and get a nice pic of my car by Blue Marsh lake, tomorrow. If i cant ill give up my spot
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
JC
Post by JC »
jamal wrote:All the ones I made were at between 65-75 quality in photoshop, which is about as high of quality and you can get while "saving for web." I think it looks fine. For comparison, here's my 15k image compared to one saved at "maximum quality," which works out to be 52k. I can't see much of a difference.
Ah, if you use "save for web" instead of "save as" it makes it smaller. Wierd. Anyway, thanks and nm about the 15kb.
Does it have to be a Legacy? :P
Kelly
Post by Kelly »
:P
Yeah.....I played around with it, and save for web is definitely the way to go. Since I'm rather anal....here's differences between 15kb & 20kb under normal saving, and then by saving for the web.
BTW....I need some help choosing what pic I should use :P
15kb saved normally
they look like poo
15kb saved for web (optimized)
20kb saved normally
20kb saved for web (optimized)
DLC
Post by DLC »
Here are mine.
The 93 (biggreen96 owns it now)
The LTD
Legacy Central
rallysam
Post by rallysam »
Your choice:
'00 Impr RS - sold
0perose
Post by 0perose »
DLC
Post by DLC »
Someone seems to have missed the size requirements...:P 43kb isn't going to fly.
Legacy Central
0perose
Post by 0perose »
DLC wrote:Someone seems to have missed the size requirements...:P 43kb isn't going to fly.
crap.. I forgot to check the size.. I have imagemagick set to resize through command line...
Post by 555BCTurbo »
Here's mine...
Brat4by4
Stratified
Post by Brat4by4 »
Here's mine. If someone could add my posting name at the bottom I'd much appreciate it. Paint & Picasa aren't cutting it.
:smt100
Or if someone wants to make a better resize of it, I'd be happy to send them the original.
DLC
Post by DLC »
c'mon Nick, read all of the requirements...245x184 is a bit tall. The image will also be smaller in kb if you can trim it down to x130
Brat4by4: link to the original and I'm sure someone can help you out.
Legacy Central
jamal
Vendor
Vendor
Post by jamal »
Legacy777 wrote:Yeah.....I played around with it, and save for web is
I say one of these.
Brat4by4 wrote:Image
:smt100
You can send it to me. Name a font.
Fix-ted...
Thank Jamal,
I think I'm going to choose between these three
DLC
Post by DLC »
c'mon Nick...151 height is still 21 more than the maximum...
Josh: I'd go for #2, then #3.
Legacy Central
