Flex or no flex
dwreck30
Flex or no flex
I need a new up-pipe and I am looking at getting a used HKS pipe. My question do I really need the flex secton like to stock one or not? Thanks.
- Derek
'06 STi
'06 STi
You should have a flex. Yes.
If the pipe is real cheap, weld a flex into it!
whats wrong with your current up-pipe? is it cracked? why do you need it replaced?
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Why don't they do it? I dunno. Maybe costs or manufacturing problems or fear of leaking.
I'd like to have a flex, personally.
I dont see any need for a flex in that piece other than to help line it up with the turbo. the exhaust manifold is fixed to the block, the up-pipe is fixed to turbo which is fixed to the block by the support bracket and the down-pipe is fixed to the turbo and the trans. The up-pipe doesn't need to flex or move under and sircumstance once installed. it moves as a whole with the engine and trans.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
You're neglecting the effect of heat, Mike. The engine and transmission are made of aluminum and get up to around 200 degrees. The exhaust manifolds are made of cast iron and get up to around 1500 degrees. The uppipe is made of stainless steel and also gets up to around 1500 degrees. They're not going to just move as a whole.
I say you should definitely have a flex section.
Also, I just remembered. The new TurboXS Uppipes have flex sections in them. Beefy awesome ones too!
Innovative Tuning
Actually they switched because now customers can't say it doesn't fit right when they install it wrong...and frankly I can't blame them.BAC5.2 wrote:Also, I just remembered. The new TurboXS Uppipes have flex sections in them. Beefy awesome ones too!
The cast iron ones never failed. I keep one here for me incase I ever need it for one of my cars.
I recommened ones without flex as long as they're made well. The flex joints will inevitably fail and leak at some point. Yes even the high dollar ones like the APS. I've seen it WAY too many times.
The Scooby
There's a flex. The 93 motor I have has a flex.
The cast iron ones had some problems. That's why they stopped making themInnovative Tuning wrote:Actually they switched because now customers can't say it doesn't fit right when they install it wrong...and frankly I can't blame them.
The uppipes had some manufacturing problems in Australia. They were sorted out, but for a while one of their guys was welding the flexes into them.
Then the problem got solved, and the flex was welded into the pipe.
