new clutch?
poseidon1787
new clutch?
Post by poseidon1787 »
can i use a stock clutch if i am doing an ej20t swap to my 91 legacy, or do i have to use a different clutch, it is front wheel drive
a legacy to be told
gt2.5turbo
Post by gt2.5turbo »
you need your clutch and flywheel to match and you should be good
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
poseidon1787
yea
yea but can i use a clutch from a 91 leg with the ej20t motor?
a legacy to be told
If your '91 is an NA, I'm doubting it would handle the torque of an ej20t. I'm not even shure about the SS clutch, as I have no experience with it. ACT does sell clutches for NA subies that would be up to the task of clamping that beotch, but as always, it costs some dough. I'd think if you were going through the trouble to put an ej20t in your OBD1 car, you wouldn't want to skimp on something as important and pain-in-the-ass to change like the clutch.
douglas vincent
Post by douglas vincent »
I am pushing 175 torque 155 whp with a $99 6 puck disk, 02 RS used pressure plate and Forester flywheel. The disc is supposedly good for 200 whp or so. Better yet, contact Kennedy Engineering for better facts.
nice
