In reading on the board, it seemed to me that most subaru trannys will bolt up to the ej22t although getting the right pieces might be confusing. I am trying to assemble the pieces.
I have a low mile 03 forester 5mt that I am planning to put in my turbo wagon. ( I have also seen that this may have not been the best option, but I am not going for super power)
My questions:
Is any flywheel ok? It seems I have seen that the WRX flywheel is larger in diameter. Is that better, or is it not usable with this combo and not a consideration?
Does the type of flywheel or the type of tranny (being push or pull) determine the clutch used?
Do I have a push or pull type in the 03 forester trans?
Can I convert the forester trans to a 3.90? (I think it's a 4.11)
If not what do I have to change out in my drive train to make it 4.11?
Sorry for the barrage of questions and thanks for the help.
Forester mt in 93 Twagon questions
I used to be full, but I'm finally MT !!
