I got the sunroof sealed, but now I am fighting a leak that is coming in behind the drivers door seal. It appears to be coming thru just about where the roofline trim turns into the winshield trim. Will try to get a pic to show exactly where.
Has anyone else had to deal with this and if so how'd you fix it?? I'm on hold putting the headliner in until I fix this.
No, I'm sure it's comming in where the roof moulding goes in behind the the door seal groove. I will probably just pull the moulding adn put sealant along the rain gutter to try to seal where ever the water is seeping thru.
