Moderators: Helpinators , Moderators
khrys771
Posts: 14 Joined: Tue Mar 07, 2006 12:55 am
Post
by khrys771 » Tue Mar 07, 2006 1:03 am
how you doin guys?
i own a Mazda 323GT turbo sedan. it uses an IHI turbo.
i have been searching on here for turbine measurements of the VF10, VF11 turbos. i would apreciate it if you guys could compare these measurements of my stock turbine to your turbine.
help me out guys, thanks please reply.
here are some pics one of the 323 forum members took of the stock 323 turbine.
inducer
exducer
khrys771
Post
by khrys771 » Wed Mar 08, 2006 12:18 am
please help me guys. i know someone has to have measured the inducer and exducer on the VF10 or VF11 turbine...
please.
Posts: 27930 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Wed Mar 08, 2006 1:28 am
The USDM Turbo Legacy VF11 Turbine is essentually identical to what comes stock on the 323 turbine, based on what was measured/pictured above.
My numbers are pretty close to the ones above, close enough that I'd consider them meausurement errors, especially on the exducer due to how the calipers were oriented.
Inducer - 2.040" / 51.816mm
Exducer - 1.676" / 42.5704mm
khrys771
Post
by khrys771 » Wed Mar 08, 2006 12:55 pm
thanks soo much bro. now i can look into doing an easy hybrid for my 323. =P
spikey
Posts: 13 Joined: Wed Mar 08, 2006 12:56 pm
Post
by spikey » Wed Mar 08, 2006 1:56 pm
The Vf8 is commonly use in Australia for the 323 the compressor bolt straight onto your exhaust housing.
khrys771
Post
by khrys771 » Wed Mar 08, 2006 3:31 pm
the aussies are telling me that the VF8 and VF12 are RHB52 series.
the VF10/11 and VJ14/11/20 are RHB5 series.
also they say the VF8 and VF12 require machincing of the RHB5 turbine housing, due to a slightly larger turbine wheel.
spikey
Post
by spikey » Wed Mar 08, 2006 3:48 pm
Sorry my bad
,it is the vf 10 that is on the automatic that fits the 323 housing the vf8 was on their manual car and are slightly bigger.
khrys771
Post
by khrys771 » Wed Mar 08, 2006 5:14 pm
no prob.
do you guys have the compressor inducer and exducer measurements also?
when measuring the wheels for trim size, you measure the outer fins.
here is the stock 323s comp.
exducer (major) 52.50mm
inducer (minor) 35.00mm
Post
by Legacy777 » Wed Mar 08, 2006 7:49 pm
I can get them for you tonight.
You're just lucky, I've got two VF11's apart
khrys771
Post
by khrys771 » Wed Mar 08, 2006 11:53 pm
thanks bro, your a great help!
khrys771
Post
by khrys771 » Thu Mar 09, 2006 5:05 am
hey josh, wheres my numbers bro?
chris
sixsick6
Posts: 10 Joined: Thu Mar 09, 2006 5:49 am
Post
by sixsick6 » Thu Mar 09, 2006 5:53 am
YOUR NUMBERS?
Thanx for giving me credit and using my own pictures in the first place.
$5.00 he measures 52.5mm major and 39mm minor, which I could have told you in the first place.
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Thu Mar 09, 2006 6:00 am
Damien, you're the 323 forum member?
khrys771
Post
by khrys771 » Thu Mar 09, 2006 6:49 am
plz dont make this thread off topic.
btw six, i'd rather have facts then guessing. so i turn the bet down.
MrSarcastic13
Posts: 86 Joined: Tue Jan 03, 2006 4:39 am
Post
by MrSarcastic13 » Thu Mar 09, 2006 7:09 am
vrg3 wrote: Damien, you're the 323 forum member?
Um....I am?
Post
by vrg3 » Thu Mar 09, 2006 3:48 pm
I was addressing SixSick6.
Sorry, Chris. No more.
Post
by Legacy777 » Thu Mar 09, 2006 7:22 pm
Didn't have time to get them last night.
I should have time this afternoon.
sixsick6
Post
by sixsick6 » Thu Mar 09, 2006 10:06 pm
Yeah, who're you?/Do I know you?
Chris- You're coming off very condescending and it needs to stop. Don't bite the hand that feeds you and demand that people give you answers immediately after you post. Not to mention use someone elses info and pictures without giving them credit. That's just foul Chris.
As said, I'll bet $5.00 that he gets 52.5mm OD and 39mm ID just like the T Bird.
khrys771
Post
by khrys771 » Thu Mar 09, 2006 11:41 pm
???? my numbers, as in the numbers he is going to measure for me.
the pics are all you, i dont claim them to be mine.
read the first post this is in there.
"here are some pics one of the 323 forum members took of the stock 323 turbine."
the credit of the pics goes to sixsick6.
i'm not wanting to cause drama, i just wanna know the measurements.
MrSarcastic13
Post
by MrSarcastic13 » Fri Mar 10, 2006 12:48 am
sixsick6 wrote: vrg3 wrote: Damien, you're the 323 forum member?
Actually now that I have read the thread instead of just looking at the pictures, damn Playboy habit of mine, I see what he meant. I am still not sure if I have the 323 turbo, doubt I do. I just have the 1994 turbo wagon. I'll check in again to see if it is what I have, and can ya tell I am a newb to this sorta thing? Coming from a Saturn, ya know.
Post
by Legacy777 » Fri Mar 10, 2006 2:52 am
Looks like you owe him $5
The Exducer is the same, however the Inducer is larger. I measured it twice to make sure I did it right.
My numbers
Ex: 52.55mm
In: 37.48mm
sixsick6
Post
by sixsick6 » Fri Mar 10, 2006 4:00 am
More than likely 37.5mm.
Just an FYI- The VJ11 measures 36mm, VJ5 measures 36mm, VC32 (T Bird) measures 39mm. I haven't measured a single RHB5 that's been any larger than 52.5mm OD. To my knowledge they're all 52.5mm OD.
sixsick6 on Fri Mar 10, 2006 7:43 pm, edited 1 time in total.
khrys771
Post
by khrys771 » Fri Mar 10, 2006 4:04 am
hmm. interesting.
what hybrids do you guys do besides the t-bird?
Binford
Posts: 909 Joined: Sat Aug 07, 2004 4:29 am
Post
by Binford » Fri Mar 10, 2006 4:26 am
We get bigger turbos.
sixsick6
Post
by sixsick6 » Fri Mar 10, 2006 5:49 am
Legacy777 wrote: Looks like you owe him $5
My numbers
Ex: 52.55mm
In: 37.48mm
Is there anyw ay that you could measure different fins and pull a 38mm or even a 39mm? It would explain another thread in a different forum in which a friend of mine used a Legacy housing and a T Bird wheel.
