2.5rs trans in a 92 legacy possible?
Besides clutch cylinders and such wouldn't I need a different ecu ,standalone ecu , or just different wiring?What kind of drive shaft would work just the oem or a modified piece?
This has been covered quite a bit before.
You should give the search feature a shot, and you'll find your answers.
