n/a brake fit on turbo
pw422
Post by pw422 »
Just want to find out if n/a brakes would fit on my 91 ss. I assume it would fit but they are not as good as the ss brakes. Reason being I have a n/a parts car and my ss needs new brakes all around and I am broke to buy new ones.
91 rio red ss 5mt
94 legacy wagon gt
95 impreza ej20 swapped
legacy92ej22t
Post by legacy92ej22t »
Very bad idea.
The front rotors will be smaller. You'd have to swap calipers and all.
N/A rears are solid instead of vented. You'd also have to swap calipers and all.
Bite the bullet and buy new turbo rotors and pads.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
jamal
Vendor
Vendor
Post by jamal »
yeah can you not just buy some cheap pads all around?
Unless you've let it go so that the rotors are all gouged up by the backing plates, I see no benefit in taking the brakes off some parts car that's been sitting around and probably has crappy brakes anyway.
I suppose you could then sell the turbo rear calipers for a good amount on nasioc or something.
