n/a brake fit on turbo
Posted: Fri Mar 10, 2006 12:31 pm
by pw422
Just want to find out if n/a brakes would fit on my 91 ss. I assume it would fit but they are not as good as the ss brakes. Reason being I have a n/a parts car and my ss needs new brakes all around and I am broke to buy new ones.
Posted: Fri Mar 10, 2006 1:42 pm
by legacy92ej22t
Very bad idea.
The front rotors will be smaller. You'd have to swap calipers and all.
N/A rears are solid instead of vented. You'd also have to swap calipers and all.
Bite the bullet and buy new turbo rotors and pads.
Posted: Fri Mar 10, 2006 3:21 pm
by jamal
yeah can you not just buy some cheap pads all around?
Unless you've let it go so that the rotors are all gouged up by the backing plates, I see no benefit in taking the brakes off some parts car that's been sitting around and probably has crappy brakes anyway.
I suppose you could then sell the turbo rear calipers for a good amount on nasioc or something.
