The Forester has been dropped...
snowjob
Post by snowjob »
Ok, I keep coming back because this was my first home, but since I've moved away from the leg, I though I'd share what I've been working on......
Here is my SF, and now with the specs
1998 Subaru Forester S with Sun Roof
Generic Cold Air intake
2005 WRX struts with H&R lowering spring for a 98 Legacy GT
STI transmission and Engine mounts
2005 WRX front and Rear Brakes with EBC Greenstuff Pads
1991 Legacy SS 19MM Rear Sway Bar
Catzkins Leather Tan interior
2003 WRX cd player
WRX Steering Wheel
Whiteline Bushings throughout
ACT lightwieght Flywheel and Exedy Clutch.( Changing a clutch with only jackstands sucks)
04 modified XT
99 LGT Limited
Subaru_Nation555
Post by Subaru_Nation555 »
Great stance, looks good.
DLC
Post by DLC »
JDM yo! Seriously though, they look great when they're set up sporty.
Legacy Central
I gotta see if I have a pic of my buddy's forester. That thing is about as low as my car...or maybe lower.
206er
Post by 206er »
that last pic is seriously awesome, great lighting and composition.
Post by BAC5.2 »
Looks like mine, but lower... and with a sunroof. Bastard.
I didn't know the 91SS rear sway bar fit on the Forester. I'll have to install the one from my 91 on the Forester.
snowjob
Post by snowjob »
Fits no prob, all you need to do is use the bushings from the 91 as well.
04 modified XT
99 LGT Limited
Post by BAC5.2 »
Sweet. What about the front bar?
Post by entirelyturbo »
The 91 turbo rear swaybar is 18mm by the way, not 19mm.
The fronts are all the same except for air-ride Legs, they have 19mm fronts.
That's all in Scott's thread in the Suspension forum.
snowjob, knock the orange out of the tails and swap the rear badge for "FORESTER" instead of "SUBARU" and that thing would look as JDM as the ones in Japan!
*Formerly DerFahrer*
wiscon_mark
Post by wiscon_mark »
Looks excellent lowered :)
185,000 miles
JuhaKankkunen
Post by JuhaKankkunen »
Nice!!!! And nice specs too 8)
snowjob
Post by snowjob »
That was the first thing I did subyluvr2212
here is the sway
04 modified XT
99 LGT Limited
