Power Switch - 94 Leg SW 250t
natkaa
Post by natkaa »
Just checking...is the power switch in the Sub supposed to work like other cars 0/D switch, where if you need increased power in exceleration you turn this on. Because when I turn it on nothing happens, what could be wrong?
You have a power switch?
Where are you? I've never heard of a 250t.
corsair
Post by corsair »
on US 90-94's, Power is a light that comes on if you mash the pedal a lot to hold shift points on the 4EAT
there is a manual switch that holds the vehicle in 2nd gear if either 2 or 3 is selected, and it might do a few other things (control hidden rockets, etc)
Sam
'93 L AWD Wagon
'08 Honda Civic Si Sedan
natkaa
Post by natkaa »
New Zealand, its an import!
