New Struts - alignment question
Bosco
Post by Bosco »
SO...I swapped out the struts in my Touring Wagon.
Got new GR2s now.
I also put in a new ball-joint, and drivers side axle/cv assembly.
I plan to make another couple changes in about a week or so... (I'm gonna put in a different steering knuckle with properly working ABS sensor.)
SO...the question...
Can I drive the car for the next week until I make the next move, and THEN get it aligned?
Or will I destroy something (other than a bit of tire wear) by driving it without having it properly aligned?
It seems to be driving if a pretty straight line BTW.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
Chef
Post by Chef »
Unless you find it drives noticeably off (i.e. pulling badly or terrible oversteer) I don't see why not. I'd try to minimise driving, but certainly complete refrain is unnecessary.
92 Legacy LS - AWD Wagon 244 000 km, Swap to Spring/Coil suspension
