Help! Replaced the 4eat and don't have any ATF flow.
supernoob
Post by supernoob »
What are the possibilities here? This is a Leg tranny into a Leg. I move the gear selector and the car doesn't do anything. I disconnected the ATF lines from the tranny and there is no flow with the engine on. If the torque converter drives the ATF pump and we know the TC is spinning, is it possible the circlip just popped out on installation? I suppose it could be a dead pump, but are there any other possibilities? I suppose there is no way to get this to work without pulling the tranny again. Has this happened to anyone? Thanks.
Stephen
